mark32
- Currently in NJ
Up to this point I've only installed one wall mount flat screen tv and have been asked to install another but not before researching a couple of things first.
I noticed during the maiden install that the kit came with huge lag bolts. I drilled pilot holes and snapped one bolt after another only half way into the wooden stud. I downsized one size (In length I believe) and that one snapped as well, so I had to go another size down in order to get the thing mounted. Has anyone had this problem and if so what size lags do you use as I can't recall which one I used.
Also, how do you determine the correct mounting height for these?
When running a/v cables and power inside the wall, do you concern yourself with separation between them. (I'd be using two separate boxes) and do you feel it's necessary to use those recessed clock receptacles for these installs?
Thank you for your time ~
