MikeyinLA
I'm new here (first post) and I found this site while looking for a date when romex was not allowed to be installed in a commercial building.
Thanks in advance!
Thanks in advance!
Thanks in advance!
Those crazy East coast folks apparently rope grocery stores
Locally (AZ), commercial work has been conduit and wire for just about ever.
Yeah, new ideas are slow to get out west. :grin:
I have never understood the mentality behind not allowing a wiring method in a place where more then likely you will be awake all day if even there was a problem like a fire,
and there will be fire escapes and fire alarm systems and sprinklers and ....![]()
Just for the record for the op, NEC- it was not allowed in building that had more than three floors above grade,
It all has to do with the type of construction... unless you lived in MA.![]()
And big concern based on the number of people in the occupancy. More people, and people less familar with the surroundings (they are not at home) makes it more difficult to evacuate the building. Therefore the fire may be burning for a longer amount of time while the occupants are evacuating, leaving them exposed to the fumes from the burning cable...
Nice to see you Pierre, it almost makes me feel bad to ask what you mean?
Other than places of assembly NM can be used in buildings with 100s of people inside.
