When was NM cable adopted as not allowed in commercial buildings?
What I tried to convey is the idea that there were discussions during the years that the larger occupied buildings were took longer to evacuate during fires, etc... the longer time was a concern due to the lethal fumes from burning NM cable.
Pierre,
The only problem I have with that is the very small quantities of lethal fumes that will come from the NM cable and other parts of the building itself as compared to the lethal fumes from finishes and furnishings of the building.
Somebody posted a picture a while back. It was of what looked like millions of #12 NM ran all nice and neat. Row after row after row, 90's offsets, etc...In a commercial building.
I forgot who posted it. It might have been Pierre.
My concern wouldn't be with toxic fumes, it would be with potential damage to cable. There is a LOT more going on in commercial buildings than in your house.
With the NM being concealed within walls why would that be an issue? In reality the conductors would be less likely to overheat being that they are not confined within a metallic raceway.
Roger
Not all the cable is in the walls.
I share the opinion that a conduit/metal cable system is a safer system and commercial/public spaces should use it.
I agree totally. I was working in a school today which was full of Romex. I think this school was built in the 70's. It seemed to me that with all the stuff above the drop ceiling, and all the people who work up there, Romex would be a poor choice as a wiring method. Just to easy to cut the cable and cause a short.
Here in CA and mostly in the Los Angeles area, which is made up of many, many city's, some have ordinances that don't allow NMC cable at all, some don't allow it in commercial / Industrial, and some go by what the code says.
334.12 (a)(2)
334.12 (a)(2)
334.12 Uses Not Permitted.
(A)(2) Exposed in dropped or suspended ceilings in other
than one- and two-family and multifamily dwellings
It is allowed in drop ceilings , but only in one- and two-family and multifamily dwellings not sure if that is what you ment to say.
So, where are the cables that would be a problem?
Roger
Hell, I don't know....every commercial building I see seems to have conduit exposed all over the place. Coming out of the surface mounted panels, going from light to light etc. If it were romex it would be a mess.
Also, most commercial buildings here have grid ceilings so I guess it wouldn't be allowed anyway.
So why not just protect those particular cables in conduit or tubing?
You don't have any wiring in walls?
Roger
