Over "here," I can find just about all three sizes in both hard and unbreakable at both the orange and blue stores.Over here, the Home Depot standard size plates are Leviton hard plastic, not nylon.
can't you get the GFCI with a plate? They are usually in nylon
what makes you think these are for GFCIs?
There are three sizes of plates--- Standard, Midi, and Jumbo. Perhaps others call them by other names but there they are in order from small to largest.
Well I almost never use the vinyl plate that come with the GFCI so I have a stack of those for the time I really need them
why in the world does no one stock white single gang decora plates, standard size in nylon?
I can get the residential grade ones in standard size, or nylon plates in midway. No supply houses have them, no home improvement centers have them... now i get to pay fedex that will probably cost more than the plates do to have them overnighted from mfgr[/QUOTE
I'd have just slapped a standard plastic plate on there until i got the other ones. Why pay extra to overnight something?
Your OP stated single gang decora plates. Most good GFCI's come with a midi sized nylon plate.
I have several boxes of plates from GFCI's that were cover mounted or had weatherproof covers installed on them. Don't know when I last purchased one gang decora plates (at least in ivory or white), don't need to.
the OP said standard size
Over here, the Home Depot standard size plates are Leviton hard plastic, not nylon. All of the supply houses I go to also have the same. No supply houses that I know of have midi plates here. It's funny how the big box stores vary across the country.
Must be a Carolinaian iowan term... :grin:
it isn't funny at all.... :-(
mid size plates nylon are about all that i use. 3/8" bigger than normal.
when you see how the drywall is finished in this part of the country,
you realize how pointless standard size is.
