jetlag
 - Eatonton, Georgia
I hope Ive have been telling customers correctly when they call for me to install dimmer switches to save on electrical bill. I advise them that dimmers dont save anything .  If my electrical theory serves me right a dimmer is nothing more than a variable resister in series with the light load.  The dimmer causes a voltage drop across it the same as a light bulb and gets hot the same way. We used to make home made testers by wiring 2 light bulb sockets in series  each bulb recieved 60 volts on a 120 circuit and would burn dim yet the total watts was the same as a single bulb .  If the bulbs burned normal the circuit was 240 v .  I still use those testers sometime because they put a load on the circuit and wont read phantom voltage like a tester.  The point Im making is the dimmer is the same as a bulb tester it uses its share of the voltage drop and the rest goes to the light circuit.
