Sorry, I just had to!![]()
Sparky,
I need some help pulling another circuit through that H/R. I'm gonna need your help. I'll feed at the panel, you pull. :grin:
. . . I was young when I made that long box . . .
see the empty conn. on the bottom, I ran a pipe from the back of the orig. box inside and is held by that conn. after I cut the thread part of making it like a coupling. hehe
Heh!
I've always wanted to know how this thing got tightened.
Look at the bottom box and the joint between the 3rd and 4th (from bottom) boxes.
The bottom box is actually a full bottomed box - the EMT in the 90? connector is connected to a KO in that box bottom.
The 3rd and 4th (from bottom) boxes are extension rings that are facing each other and are somehow tied together. . . inquiring minds want to know how.
I saw the shadow that looks like a keyhole slot, also, but I gave more weight to the pair of holes on the box sides towards the lens and the fact that the third from bottom extension ring is welded, not stamped.
Post # 10 made sense to me . . .How the whole cluster---- is held together is what I'd like to know.
Absolutely. I've used them on several occasions. A pair of them works great when you have two things that only have top or bottom KO's and they're mounted side-by-side.No one has even mentioned the 90 degree EMT compression connector at the bottom. Do these even exist? :-?
Look up a Halex #02905B.
Can I run EMT pipe to and from a extension ring attached to a 4sq. J-box??
