Very skilled electrician
What?s wrong with running 100 red wires, 10 blue wires, 4 yellow wires, 1 black wire, and 3 green wires into a box with out leaving a road map or installing a Halon system?
When I look at that I see money in my wallet and a work order that say ?take Advil before getting to the job?.
Red does seem to be the predominant color for wires here!!
And its just amazing that yellow was the only size wirenut they needed!!
Oh, and I appoligize for calling this person an electrician.
Steve
What’s wrong with running 100 red wires, 10 blue wires, 4 yellow wires, 1 black wire, and 3 green wires into a box with out leaving a road map or installing a Halon system?
I'll need the dimensions of the room so I can calculate box fill.
100 red wires,
10 blue wires,
4 yellow wires,
1 black wire, and
3 green wires
Cruz,
I count 92 reds, and 3 blues. Where is the green one ?
Wonder about the conduit sizes required to pass this quantity of wires ?
Rough guestimation is 800 cu in box for these conductors, if #14 awg.
Just guessing.
Cruz,
Just guessing.
Are you good at those 'guess how many jelly beans are in the jar' contests?
Cruz,
Just guessing.
I did not count.
I put a purple dot on the end of what I think is a green wire.
attachment.php
It looks like LV wiring such as FA or irrigation.
That is possible. I didn't actually take this photo - one of the HVAC designers took it, and this jbox just happened to be in the photo. Although I can't imagine there would be that much of either wiring in this building. And I wouldn't put it past whoever did this, to use some other color for a neutral.
