Hendrix
- New England
Ground down, so I don't have to stand on my head to read my tester.Ok, should it be installed ground up or down? :grin:
No however if you do it must be gfci protected. 210.8(B)
If you have a receptacle the plate cover color must match the receptacle in the ladies bathroom.
I heard new code requires pink for ladies room rec and switches
So to use a stainless or brass plate you would need a stainless or brass receptacle
Is a bathroom required?
Not here, we have Amish that still build houses without indoor bathrooms (plumbing) or electric.Yes, under the Building and Plumbing code with some exceptions.Is a bathroom required?
I think there is a proposal to require that all commercial bathrooms use RMC and THWN for all wiring. (that oughta keep this going)
Ya I want to see that get passed, I will hang up my bender if it does,:roll:
MMMMmmmmmmmmmmmmmmmmmmmmmm.................
And, a separate EGC run.ITS got to be in RMC 3/4" OR LARGER.:roll:
Redundant grounding and hospital grade receptacles, one receptacle per branch circuit.
