Some of the gases present in bathrooms maybe should make us consider article 500 wiring methods
Class I Division I ?
At times there can be ignitible concentrations of flammable gases.:grin:
C'mon, Dennis.... how are we supposed to stretch this thread out to 150 posts if you answer the OP on the second one?
and does the metal box (if used) need a ground wire attatched to the green ground wire if the receptacle itself is "self grounding".
I thought you wanted to strech this thread to 150 post C'mon 480 sparky:grin: you must be slacking off
I think there is a proposal to require that all commercial bathrooms use RMC and THWN for all wiring. (that oughta keep this going)
"All righty, then!"Exception No. 210.8 (G) 44....A new provision was added at 210.8(G)(44) to require GFCI protection for all 125-volt, single-phase, 15- and 20-ampere receptacles installed in commercial/Industrial bathrooms/restrooms be supplied by Extra Heavy Duty (Read Schedule 80) PVC conduit encased in knot less than 12" of concrete in walls and 24" of red concrete where fed through floors! Where fed from the keyless outlet on the ceiling... 18/2 lamp, vacuum cleaner cord or type SJOW shall be permissible!
Who purposed that, and why?
Your not taking that post seriously are you?:roll:
I think you missed the under his avatar.Who purposed that, and why?
