jetlag
- Eatonton, Georgia
Thanks iwire
Thanks iwire
You are correct , I had a wrong mental picture of a DC MWBC . What is still weird is the code states we can not connect loads in series but on a MWBC if the loads are equal there are 2 loads in series with 240 v and the voltage drop across each is 120 v . The same as the old 2 bulb in series home made testers , burn normal 240v , burn dim 120 v (60v for each bulb). In other words if both loads are the same on a MWBC you can remove the neutral with no affect, leaving two loads in series with 240 V .
Thanks iwire
That is false, you can have DC multiwire circuits.
