rhamblin
- Kaukauna, Wisconsin
I have a customer that just purchased a drill press, sander and chop saw. The current for each is 3.5, 6 and 19 amps respectively. I am trying to find a way to put them all on one circuit, because there is limited space in the breaker panel. All items are 3 phase. So if I put them all on a 3 phase 40 amp breaker, it will cover the power required for the items. 1st question: Is it permissible to run 3 - 40 amp receptacles in 3 seperate 4 sq boxes fed from the same circuit. I have seen this many times with 15 and 20 amp circuits, but I don't think I have ever seen more than one receptacle on the same circuit over 30 amps. 2nd question: Is it permissible to put a small (3.5 amp motor) on a 40 amp circuit? And likewise for the other items.
