- Lockport, IL
- Semi-Retired Electrical Engineer
I am at home, and have a short time before I have to leave for jury duty.  Checking office email, I found the following question.  I don't have time to try to look this up in the on-line NEC, so a quick reply would be appreciated.
A lab needs to route an antenna cable to the roof. It will be in conduit, and the conduit will run through a vertical shaft. At the top of the shaft is a grating, and above that is sky, so the shaft is exposed to the outdoor environment. The design called for (I seem to recall) rigid steel conduit. They want to use aluminum, because it is lighter and easier to install. Since the conduit is simply intended to protect the cables, and perhaps allow them to run more antenna cable later, does it matter what the material is? More of concern to me is the question of whether aluminum is rated for use in outdoor areas.
So, do you think aluminum is acceptable in this installation?
