Enclosures marked with a type may also be marked as follows: .
A Type 1 enclosure may be marked ??Indoor Use Only?? .
A Type 3, 3S, 4, 4X, 6 or 6P enclosure may be marked ??Raintight?? .
A Type 3R enclosure may be marked ??Rainproof?? .
A Type 4, 4X, 6 or 6P enclosure may be marked ??Watertight?? .
A Type 4X or 6P enclosure may be marked ??Corrosion Resistant?? .
A Type 2, 5, 12, 12K or 13 enclosure may be marked ??Driptight??
A Type 3, 3S, 5, 12K, or 13 enclosure may be marked ??Dusttight??
For equipment designated ??Raintight,?? testing designed to simulate exposure
to a beating rain will not result in entrance of water. For equipment
designated ??Rainproof,?? testing designed to simulate exposure to a beating
rain will not interfere with the operation of the apparatus or result in wetting
of live parts and wiring within the enclosure. ??Watertight?? equipment
is so constructed that water does not enter the enclosure when subjected to
a stream of water. ??Corrosion resistant?? equipment is so constructed that it
provides degree of protection against exposure to corrosive agents such as
salt spray.
??Driptight?? equipment is so constructed that falling moisture or dirt does
not enter the enclosure. ??Dusttight?? equipment is so constructed that circulating or airborne dust does not enter the enclosure.
