mcelweec@gmail.com
CMAC1
- NYC
- Electrician
If a panel is placed behind an access door in a closet,is it in a closet?
Yes a clothes closet,with a hinged access door which satisfies all clearance issues.The question is whether this is considered a separate room?
No the fact is it is not in a closet until the door is opened,therefore it is under supervision when the door is open ,therefore is it a fire hazard?
Hypothetical,with the basic question,define a room?
I know that no one else reads the section the way I do, but I don't read it as a blanket prohibition on installing a panel in a clothes closet. The rule says that you cannot install a panel in the "vicinity of easily ignitible material". The clothes closet is just an example of a location that may be in the vicinity of easily ignitible material. I have seen clothes closets big enough that the panel could be installed an not be in the vicinity of easily ignitable material.
How can an access door satisfy the dedicated space requirement? {110.26(F)(1)}
OK let's call it a door?
