Barndog
 - Spring Creek Pa
I am doing a Range install where we are converting from gas to electric. I have to run new wire from panel to range approx. 50 feet. The intall sheet says use a cord rated at 40 or 50 Amps. my question is the nameplate on the range is 12.9kw and at 240v that is 53 amps. am i ok with using 8/3 wire along with a 50 amp 2 pole breaker in the panel? The range is a double oven and it is a Maytag.
Thanks in advance for your help
