It shouldn't be to hard to convert one or two and do a visual comparison. Even better, use a light meter with only one of each fixture on at a time.If I retrofit a fluorescent troffer from 4 - lamp T12 to 2 - lamp T8 (high ballast factor) will this result in a decreased amount of foot candles at the work surface (desk)? The lighting rep won't tell me.
Thanks for the welcome! What more would you like to know, and I will try to explain.Hey, home theater guy. Welcome to the forum!
Can you explain more about the circumstances?
From my experience, if you retrofit a 4 lamp T12 to a 2 lamp T8 high power ballast, the T8 is brighter, not outstanding brighter. Never measured it with a light meter though.If I retrofit a fluorescent troffer from 4 - lamp T12 to 2 - lamp T8 (high ballast factor) will this result in a decreased amount of foot candles at the work surface (desk)? The lighting rep won't tell me.
You're welcome. I'm a home-theater guy, too, so it was easy to decipher your forum name.Thanks for the welcome! What more would you like to know, and I will try to explain.
If you want brighter, go with four T-8's, or at least three.From my experience, if you retrofit a 4 lamp T12 to a 2 lamp T8 high power ballast, the T8 is brighter, not outstanding brighter.
Nope. The ballast wouldn't work. I'm talking about fixture replacements in this instance, which are still 8' long.If you retrofit a 2 bulb 8' Slimline with a 4 bulb 4' T8 kit, then can you install just 2 T8s and have it function?
101101-1359 EDT
Larry;
How many different manufacturers are there for these kits? I looked on the Lithonia site and did not see that they had a kit.
If it functions, then is the input power about 1/2 compared to the 4 bulbs? My guess is yes.
101102-0759 EDT
iwire:
You are an early riser.
Thanks for the information.
My son is part owner of the building he occupies. Their largest tenant won't sign a new lease unless the T12s are replaced. Scare tactics by phone from Grainger and a local electrical supply house, actually the electrical supply is just next door, that T12 bulbs won't be available. Also from our experience T12s seem to be of low quality these days, especially GE from China.
So my son had talked to his electrician about conversion. There are about 160 fixtures that need to be converted. Since T8s may provide a higher light output the possibility is to convert every other fixture to T8s and only lamp those converted units. All the fixtures are end to end so this may be a satisfactory solution.
The basis of my original question was that if all fixtures were converted and only half lamped, if possible, that this might be a suitable solution to reduce power consumption, and still provide adequate light and more uniform light than if every other fixture was converted. By half lamped I mean each fixture would only have 2 bulbs instead of 4.
In my son's own area he plans to quit using the Slimlines and instead use 4' fixtures with cord and plug and locate these closer to and in better locations for needed work light. Then use 4' fixtures instead of the 8' for general lighting. This will reduce the total lighting load, provide better lighting where needed, and easily allow selective lighting. This means individual machines get their own light or lights. The lights for a particular machine only need to be on when needed, and likely would be powered from the machine.
101102-0759 EDT
iwire:
