Anyone else work for companies doing this?
I'm in the process of replacing 14, 8' T12 f96 60 watt single pin two lamps a fixture with T-5, 54 watt HO's two lamps a fixture, took me forever to find a company who made strip fixture with T-5, 54 watt HO lamps, at 6100 lumens per bulb or 12,200 lumens per fixture it will give allot more light for less wattage, I have done many T-12 to T-8 changes and lamp for lamp they always give off more light, just take a few seconds to light fully, always use the motorola electronic 3-wire ballast for 2 lamps or the 5-wire electronic for 4-lamps, Motorola also makes these same ballast for syvlaina, and are 120 through 277 volts so no need to stock a bunch of ballast, if you get ballast that are 120 or 277 they won't operate on 240 very good, and once you have used them on one or the other voltage you can't reuse them on the other voltage, so make sure it has 120v-277v or 120v thru 277v on the ballast, not 120/277 or 120v or 277v
T-5's have the highest lumen's per watt availble as of right now (not including LED's), but the ballast are getting hard to get, they have a chip in their ballast that is also in the I-Pod, and there is only one manufacture of this chip as the other two went belly up, I hope this gets better.
City Electrical Supply is selling a retro kit for T-8 32 watt to T-5 non HO lamps, it's a plug and play type retro fit, with funky lamp adaptors, and while it does lower the wattage, it doesn't really increase the lumen out much, so if your not wanting to get brighter but use less energy then this might be the ticket. I'll try to find a link to it.
I found it:
http://www.ces-us.net/images2/Retrofit%20Spec%20sheet.pdf
