Speedskater
- Cleveland, Ohio
- retired broadcast, audio and industrial R&D engineering
You run the IG's exactly the same way you run the Hot wires.So if you are running a dozen 20 amp circuits you run a dozen 12 AWGs IG conductors all the way back to the main bonding jumper?
If you start with one big Hot wire and then split it to several smaller Hot wires.
You split the IG at that same point as the Hots.
