ptonsparky
Tom
- EC - retired
One of the methods to solve the tripping of AFCIs with older vacums etc is to use a surge suppressor of some sort with that piece of equipment.  A strip, small plug in module or whatever.  We set up a Leviton 5400-TLS to test.  Worked just fine at least on the drills we were using.
I had always thought that the TVSS was to protect the equipment from line side problems. Now it appears that they work equally well to protect the sytem from load side disturbance.
Have any of you had a chance to use a panel mount TVSS along with the AFCIs and if so have you noticed the performance of the AFCI?
Looks like we will be installing at least one easily accessed recept style TVSS on each receptacle branch circuit protected by an AFCI. I don't like to get the calls from unhappy customers.
