101123-1005 EST
Use GE RR series relays or equivalent and any number of switch locations can control a load and all switches are UP for on and Down for off if you choose.
This type of system also means that without pilot light information you can turn off or on a light that is out of sight. Also very easy to add new switch locations. 100 ft to a switch location is no problem.
My kitchen lights are controlled from 5 locations, the garage 3, breezeway 3, outside lights from many, several more in 2 positions, and every switch is up for on and down for off.
Switch wiring is easier to install than full voltage switching.
Problem is these relays are excessively expensive and should not be.
