Those who install split receptacles in residential construction please reply. In wiring receptacles around a room where in some instances one receptacle on a yoke will be switched and the other hot, how do you handle the problem of over-filling the box? They will be on the same circuit.
The space requirement for two 12/2 NM cables coming in and two going out to the next split receptacle, plus the yoke, requires 24.75 cu.in. The boxes we have available here aren't quite that large. How do you handle this?
Thanks for sharing your experience.
