Eddy Current
Someone i work with said it was against today's code to use the emt as grounding. I was wondering isn't that what you're doing when you put a ground pigtail in?
It could be a local amendment.
Here in PHX. We have to use a conductor in EMT.
What a stupid amendment. :roll:
Some us simply do not trust EMT after 10 couplings
I am sorry you do not trust the quality of your own work. :grin:
The great thing is you are always free to add an EGC if you want.
Now can can you explain how it is the EGC splices never fail in a wood framed home?
Bob we have all seen jobs where emt has seperated.
All the places I ever worked demanded a ground wire
I trust my work but not others. If i did not tighten that screw then I have reason not to trust it.
I am missing the logic.
The logic is, the NEC is minimum. Installing a EGC in EMT is a great way to go above and beyond. Kind of like keeping service conductors enclosed in IMC.![]()
Yes, and we have all seen bad splices so I guess we should prohibit those as well.
Sure they did.
So you trust others to be able to make a good splice but not to turn a screw.
Bob, what is your problem? NEC is a min code. Some of us want a bit better quality.
You admit you seen them come apart. Your smart enough to know what can happen.
No we can't do much about poor connections on anything. This is about wanting the best we can. If your doing commercial work and adding a ground wire makes or breaks you then you bid it far too low.
Your more than welcome to do it your way and I will do it mine. Both of us will pass.
The OP asked a direct question and we gave him one. He should check local codes.
With that said I generally still run a ground. Customers expect it, and we are in the business of making a living off labor and material.
