I've had a couple of those arrow T-75 guns. Piece of junk. They jam a lot, and I ended up chucking one of `em into the trash.
I finally replaced the first one I bought back in '02 or '03 last year.
The box you pictures above, the #7510S, is that the exact staples that you used? I ask because I was about to order them on Amazon and I saw a couple complaints about them not going in all the way so I was wondering if maybe the shorter leg staples might work better?
They're not designed to 'go in all the way'. How far 'in' should they go? The stapler doesn't know if there's 14-2, 14-3, 12-2, 12-3, 10-2 or 10-3, so there's no way it can 'go in all the way'.
There's no requirement that any staple you use, with a gun or by the old hammer-n-finger method, be 'tight' against the cable.
Yep. I staple into the 2x3's that form the top and bottom flanges, not the particle-board web.
I figure that once the staple hits the NM it stops, whatever size NM you are using, similar to my low voltage staple gun. I like the staple to be a bit snug so it holds the cable straight instead of letting it droop in between.
The bottom of the top flange is 1.5" thick, as is the top of the bottom flange, but, if the flooring is done, the top flange should be safe.Hmm, I've stapled to the top ledge of the bottom 2x3 a few times in basements that probably won't get finished but it doesn't seem like a really safe place to staple to nor can you get more than about two cables next to each other.
Yer welcome. By the way, I bend the nail-tips down on the other side of the web if they're loose in the particle board.Larry, I like the way that looks and I wouldn't have thought of turning the stackers sideways. Thanks for the idea!
I'm not a fan of the staple guns because like someone else said they can only be used 60% of the time. I get annoyed trying to get at rope in certain angles with those things. If you are gonna do a bunch of rope u should make some of these.
T75 all day long. The staples aren't that much... maybe $9/box. It won't work in ALL staple situations, but it works for 75% of 'em. And you can staple NM in places you would never be able to hammer.
Just make sure to use the staples designed for NM. I carry an empty box in the truck just to show the occasional inspector who's never run across them.
334.30 Securing and Supporting. Nonmetallic-sheathed cable shall be supported and secured by staples, cable ties, straps, hangers, or similar fittings...
