LarryFine
- Henrico County, VA
- Electrical Contractor
Bonding plastic pipe.what does one use a non conductive wire for?
First it was table 2 now it is table 3
Well its both table 2 is the non conductive and table 3 is the conductive wires. What i think they are doing is separating the wires, hot wires on one table and neutral and grounds on another. There is also another table that shows what size bonding wire to use.
non conductive
one of the other guys there said they have their own rules that go above and beyond the code.
Also about 10 people that helped write the 2008 code book work at the place where this is getting inspected, so im not sure how much that has to play into it.
Roger,
See what you started ?
That should be "non_CONDUCTING" wire, maybe.
Of course, you know that.
Wonder how many extra posts that will elicit? {^,^}
Imagine Dave going back to his Class, and repeating this discussion, HA!
I'm fairly certain those 10 people have nothing to do with any of the installation at this site.
They might have had something to do with the paper that has these tables though. I don't have a scanner or anything so im going to try to take a picture of these tables they gave us and post them here.
Although there are more than 10 members plus alternates listed as CMP#8 members there certainly is not 10 members represented by the same organization. I don't think there are even 2 of them represented by the same organizantion, was not going to take the time to verify this but seems very likely.
I think that is the key, this is addressing "Control Conductors" and #10 is not normally used for controlsTable 2
Number of Control Circuit Conductors in Conduit
Roger
Roger
From what I can see I am guessing it is someone's own chart for their own use and is not part of the NEC or even published by NFPA.
That was pretty much established earlier in the thread.
Roger
