I was working on a friends electric this past weekend and found it very interesting. The issue was no lights or power at a shed. Ok, sounds simple. The shed is fed underground with a 20A-1P branch circuit using #10 underground wire. The outside temperature is about 5 degrees. The wire enters the shed and splits to 2 different wires. the first set goes to 2 receptacles and the other goes to a switch which breakes the hot and serves a switched receptacle for an overhead flourescent light. Sounds pretty simple. I get ther and put my meter on the receptcale and get 120V and plug in my circuit tester and get 2 orange lights (this means ggod). I get an incadescent drag light and plug it into the first receptacle where I just read the voltage. When turned on, nothing happes liker there is no power. I plug my circuit tester in the top receptacle of the duplex. Turning the drag light on and off acts just like a switch turning the circuit tester on and off. I remove the tester and put my meter on it (hot to ground). With the drag light off, I have 120V, but when I switch the light on, the voltage drops to just about zero. Well, I definitelly believe there is a problem.
This is where I am confused, what would caust this to happen? If it was a loose neutral, the light would't turn on nor would you see a drop in voltage. I checked the splice at the main JB and all was good. I took the N and hot apart and re-did the wire nuts and checked power at the JB with the drag light. All was good at the JB. I also re-did the N wirenut at the switch. Put it all back together and the problem was gone. This one has me baffled. Also, when plugging in a small aircompressor, it will run with the voltage reading 120V. every once in a while it will choke and I will see the voltage drop to like 100V then jumps back up to 120V. If I plug the compressor in at the house, there is no problem. I am thinking because the shed is further away and it is winter, the shed is more susseptable to snow/ise on the overhead transmission lines to the pole transformer. Any thoughts?
I just found this whole thing interesting.
