jwelectric
- North Carolina
Could you tell me why metallic piping and fittings between the sections in question does not bond them together? Maybe even with less resistance than a bonding clamp that depends on the pressure of the screws in the clamp to maintain continuity?
Water heater is not likely to have a bypass valve. Many new water softeners do have bypass valve as part of unit. Many plumbers have and still do put in bypass valve ahead of softener connections. If this is metallic piping and valve why would you need to install a bonding jumper? Hot and cold water systems often do have metallic mixing valves at showers, laundry, etc that provide highly conductive path between the two.
If the valves are not allowed to be considered bonding the pipes on each side of the valves then we should have to bond around every fitting in the system.
The argument that a bonding jumper at the water heater is easier for inspector to verify is simply stupid. How does he know there is not an isolating device someplace else if all he is looking at is the water heater. He needs to do his job and look at more than just the water heater. If new construction he was there at rough in, maybe he could have opened his eyes long enough to look at the plumbing a little.
Why would an electrical inspector look at plumbing? Are they going to turn down the plumber if there is a nonmetallic fitting somewhere in the plumbing system?
Why would the electrical inspector even care if the plumbing pipes have continuity? What benefit would either the plumbing or electrical gain if the plumbing was total metal? What does it matter if there is no continuity between the hot and cold pipes?
Is there a requirement in either the plumbing or electrical code that requires the plumbing to have electrical continuity?
