lakee911
- Columbus, OH
My GDO has been on a GFCI with no problems. I put the GFCI recept. down low and a regular one up high.
I did your search on several search engines, and with several variations....not a single story came up.
Can you find one single story of a person getting electrocuted while utilizing the outlet normally used for the door opener? I'm not talking about the other outlets in the garage, just the door opener.
You're missing the point. If instead of making the door opener outlet GFI, the code instead mandated the proper number of outlets in the garage in the first place, people would not be tempted to use an outlet that is otherwise inaccessible without a step ladder.
You're hanging your hat on a story where the main point was whether 14/2 versus 14/3 was used? The only way I can read that is that the garage was wired as a MWBC without a ground. So how does that apply to a discussion about GFCI on a properly wired garage door?Sorry, his name was Issac Lawrence.
http://www.google.com/search?q=isaac+lawrence
Check out the YouTube videos. Granted, there were other violations, but if the garage door were GFCI protected...
No, never heard of nusance trips on a gdo. Besides, I thought a gfci is not required if it is a single outlet for a dedicated apliance.
Rick Christopherson said:However, if that was the sole reason behind the change ($$$) then it would still be permitted to use a single (non-duplex) receptacle for the door opener without requiring gfci.
If there is close to a million homes built each year and nearly all of them have 1 maybe 2 door openers; how many new gfci devices are added just for the doors? That's a lot of money, and it paid for a lot of lobbying to get the rule implemented in code. That's why it is irritating.
That went away years ago, What code cycle are you using.
We are on the 08 but still on 05 for residential. (MRC) When was GFCI requirments changed? 05?
The '05 has an exception to allowed a single recep. or a duplex recep for two appliances located within a dedicated space for each appliance that, in normal use, is not easily moved from one place to another and is cord and plug connected. This outlet would not need gfci. In '08 that exception was deleted.
Or tell the home owner to keep handy an 8' long 2x2 with a nail pointing out the end of it,![]()
Oh No! With such a life threatening amendment, the home owners in your city must be dropping like flies.we have a city amendment that kept the single outlet for the garage door recept...:grin:
When you guys adopt the 2011 you will have to install the gfci somewhere accessible.
Accessible or readily accessible? Didn't they already need to be accessible before 2011?
I should have written readily accessible-- thanks.
Oh No! With such a life threatening amendment, the home owners in your city must be dropping like flies.![]()
Doesn't readily accessible allow the use of a ladder to access the device?
So it wouldn't change the location would it?
If you have to use a ladder then it is NOT readily accessible.
Accessible, Readily (Readily Accessible). Capable of being reached quickly for operation, renewal, or inspections without requiring those to whom ready access is requisite to climb over or remove obstacles or to resort to portable ladders, and so forth.
