Rewire
- Lake of the Ozarks
you do this for free and I have more work for you at the same rate LOL
			absolutely.Hello,
I installed 2 ceiling fans with light kits last week. Tested them and it worked fine. FYI: one of the light bulbs in the box was broke.
Customer called two days later and said one of the fans stopped working but lights still do. I came back and tested fan and switch. Determined its a bad fan. She knew of bad bulb broken in box during day of install. I said perhaps the fan was dropped and now it just kicked. Took fan down and she returned it to store and got new one.
Should I charge to install new fan as it was defective?
Thanks.
In the future, handle the situation as follows;
When you talk to the customer, inform them that you will absolutely warranty your labor, but if its a problem with their equipment you will be charging for the diagnosis and the return trip to hang.
Before the tools come out, have them sign the contract agreeing to pay if it is not your fault. If they won't sign or argue, you leave.
I've yet to have a problem using this policy. Leave it to the customer to try and recoup some of their extra expenses incurred from whoever supplied the faulty equipment.
I've had a few similar situations. Freebie if a good customer. $25 or so if not as regular. Most customers will remember the favor and call you back again. They usually understand a small fee to cover going out to them.
Why not just have it in your proposal and invoices like I posted in post 2? and they should be reading it before they sign, or you could put a space next to it for them to initial it so it will show they did read it?
... Then when I got on the highway and ran it up to 80, there it was again.
Another thing I've run into 3 times in the past is wireless remote codes in town houses. The day after installation, you get a call from the client saying the fan/light go on or off by themselves. Turns out the code is set the same as their neighbor's RC. In all 3 cases, I went out to fix it FOC! I don't know about everybody else's clients, but mine are well worth it!
IMHO, eating a call like that every now & then will pay you back in spades over the long run! I'd much rather have a happy customer telling all his/her friends about this wonderful electrician that helped him/her out of a jam than a mad customer who will never call me again or refer me!
So you get your service call fee for an hour! Is it really going to kill your business to bend a little?
Look at the big picture, not just your hour of replacing a fan!
we get a lot of referall business, but its usually from a few select customers. for the most part, people never rave to their friends about great service unless asked.
and its been my experience that if you do something for free, they expect it next time, and some even get upset when you refuse to do it at no cost.
I can't agree with this line of thinking. Time is money and someone has to be paying for it. There are rare circumstances, but to routinely give free service in these situations is setting yourself up for eventually pissing them off.
Hello Eveyone.
They have other work for me to do, so they say.
I understand your point about good will but your example doesn't apply since you did not furnish the parts.I took my car into the dealer to have some work done. Part of the work was to turn the front rotors. I had reported a small vibration that got worse when braking. They finished all the work and test drove it, fine.
I picked it up and it was ok, at first. Then when I got on the highway and ran it up to 80, there it was again.
I took it back the next day saying we missed something. They took it in, turned the front (again) and rear rotors. Drives great...... No charge! Well, I would have paid them because I knew they didn't perform the rear rotor service the 1st visit. I may or may not have been willing to go back to them later since I told them the symptoms and I expected them to fix the problem. Since they did not charge for the 2nd visit, I fully intend to return to them even though I believe I could get a lower priced service elsewhere.
Sometimes it's good to give in.
