Mixing branch circuits and unprotected service conductors in the same raceway.
It looks like a 1 piece disc / meter combo and likely was listed for such use. Was there a chanel inside to keep them apart ?
Ran across this last week, an old over head temp that was left to power the well. POCO paid an EC to convert the well service to underground to clear a low service wire violation.
no GFI on 120V recep.
The yellow stick.
Is that one of those POCO uses to pull the fuses off the pole?
send some of mine too..Besides the seal tight banjo string, you need some nice snow in the back ground. I've got plenty to spare and will be glad to send a few tons in your direction.![]()
Well your the utiliy inspector and it looks like a meter and seal. Did you look inside to see if you had a divider ? If not you should not passed it.
After a second look and seeing its fed in center i think it likely does not have a divider.
Yes, I am the utility inspector,........I'm not allowed to ............ breach any electrical enclosure.......... .
Typically, panels like this which are designed for and underground feed will have the utility side come in one side or the other.
Yes, I am the utility inspector, however, I am a non-union employee at a utility where all of the line crews are union. It doesn't matter that I've been a licensed electrician longer than most of them have been out of high school. I'm not allowed to carry any tools or breach any electrical enclosure. I narrowly avoided a union grievance last year when they found a 2" pvc sweep in my truck.....ahhh, but I digress.....I flagged this job for denial of payment yesterday after a week of calls to the EC who installed this went unanswered. Maybe lack of payment will get his attention.
