If one of the legs on a 3 phase system has a voltage higher than the other two phases how would the line current on that phase compare to the other two phases? Would it be higher on the other two phases. For instance on a 208/120 system if 2 of the phases were 120V L-G and the other phase was 150V L-G would the current be higher on the 150V leg? My guess is that it would be higher.
Would it matter weather the load was a wye or delta load?
Could it be said that the higher the L-G voltage is on a given phase the highe the curent will be fo a balanced load? Or must you also compare the relationship between the L-L voltages?
