milwakee has a quick chuck for extensions now. They work great.
... really create a vacuum when it comes to retaining its grip on the auger and not rounding out the setscrews.
You can still use your long augers as long as the auger is bigger than the quick disconnect. I usually bore a large hole when drilling in logs.
You either baby sit those types of jobs and charge accordingly or trust someone else and still charge. Not low bid projects.
Thanks for the replies guys, I think I am going to pass on this one. Sounds like it could be a nightmare. No piers, solid down on foundation. If holes are not correct to start with fixing could be trouble.
Any chance you can observe the work in progress? It would make for a most valuable education.Thanks for the replies guys, I think I am going to pass on this one.
