I have a customer that wants a gen install that has me questioning the best way to accomplish this
200 amp main panel and 100 amp sub panel to a detached garage
garage panel has a 3 wire feeder from the main panel
customer wants to control whole house, havent did a load calc yet but dont think this will be a problem with the mid size gen set he is looking at, as the house has oil heat
what has me confused is this, with a service rated transfer switch, the main panel will then become a sub panel with the neutrals and grounds seperate, correct?
can this be done correctly using the existing feeder to the garage, or will the garage feeder and also the range and dryer 3 wire ckts need to be changed to 4 wire since they now will originate in a sub panel
i need to incorporate the garage panel into the generator because the well pump as well as 2 freezers are fed from the garage panel
