shepelec
- Palmer, MA
I believe a lunch break would qualify as the only necessary break in an 8 hour day.
I could be wrong, but I believe by law it's 15 minutes for every 4 hours worked.
Dennis, again California as example, (don’t know about North Carolina) If you work at least 3.5 hours in a day, you are entitled to a 10 minute rest break or every 4 hours worked, check this site out it’s a simple read: Calif Labor and Employment Law. Acording to this site 30 minute lunch if work 5 hrs but this can be negotiated.I believe a lunch break would qualify as the only necessary break in an 8 hour day.
..........One particular job that took me 1 3/4 hour to drive to took the crew 2 1/4 hour............
Perhaps this is due to you driving your spiffy new empty Avalanche with it's asphalt-rippin' 5.3l V8 yanking you down the road with 320 ponies, whilst 'the crew' is plodding along with a fully-loaded Astro with 189,000 miles on it's inline 4 with 12-year old spark plugs.
Legalistically it looks like 10 minute breaks are required if work 3 ? hours or more and every 4 hours with the 10 minute break near as possible in the middle of the 4 hour period (or simply every 2 hours). So it doesn't look like the 30 minute lunch can replace the 10 minute breaks (again this not in all states).I thought that you were req. to give a break every 4 hours. So if you work 4 hours then lunch is your break. 4 more hours and you go home-- at least that was my understanding.
yeah, I wishPerhaps this is due to you driving your spiffy new empty Avalanche with it's asphalt-rippin' 5.3l V8 yanking you down the road with 320 ponies, whilst 'the crew' is plodding along with a fully-loaded Astro with 189,000 miles on it's inline 4 with 12-year old spark plugs.
In MA it says "If you work more than 6 hours your allowed an 1/2 break, unpaid".
I would rather have a full break or no break at all. If I am only having an 1/2 break I am also only 1/2 working![]()
1/2 break if you work 1/2 a day..... Since a day is 24hrs...![]()
