I recently took AMTRAK to Washington for work. There are 120 volt three wire convenience outlets at each seat. Having recently attending a Mike Holt Code Changes seminar, I had gotten a great deal (free) on an AEMC Outlet/GFCI tester. I was guessing that the outlets would be GFCI protected. When I plugged it in, only the center yellow indicator lit, indicating no ground. I took it into the restroom where there is a GFCI receptacle, and it didn?t have a ground either. Pressing the test button did not trip anything, since there was no connection to the ground prong.
Information I found on AMTRAK car wiring states that the system is a 120 volt ungrounded delta, and that the outlets are GFCI protected.
NEC states that it does not apply to rolling stock.
Very strange. I?m still trying to figure out if it is safe or not, and whether the GFCIs would ever trip.
Any thoughts?
Any thoughts?
