mivey
That would be good. How about it Justin?I don't think this would be code compliant but wouldn't it make sense for the manufactorer to go to the NFPA for an opinion?
I did not want to bring out the big guns right off the bat.:grin:That doesn't mean anything, it's not a "tripple dog dare".
noAnyways, let me ask a few questions to the naysayers.
At what time and point does this installation become a code violation?
Is it a violation when the two boxes, devices, and NM is installed in the walls with no power applied?
If the answer is yes, then where can I find in the NEC that it is a violation to have wiring installed in a building with out power to it?
I really don't know. But when you power up an in-wall wired receptacle with an extension cord it sure feels like it. Too much inbreeding between premise wiring and utilization wiring. The other issue is that we don't know who it belongs too (who is the governing authority) so it looks too much like a loophole.Is it a violation to use an inlet to feed in wall wiring?
And I did not remember having any heartache when Larry posted the devices he made a while back. The difference is I have confidence in Larry's work but these kits are essentially allowing open range for anyone of any skill set to install what is essentially house wiring without meeting any kind of qualifications or having any kind of oversight. I thought we were trying to migrate away from that as a society.I kind of stayed out of this debate as I myself didn't see much wrong with this idea, as I have done very similar installs to achieve the same results,
The breakers, wire, panels, etc. we install are also UL listed but there is at least oversight on our industry as to the craftsmanship, responsibilities, etc.But what I'm seeing is this is a UL listed system and listed to be installed as a system, how is this any different then the requirements of many LV lighting systems we install as a complete system? I know here in Indiana if this system has a UL listing then its good to go, and I have read that in most states this is also true.
To me if a system (not just the components) is UL listed then it should be above the authority of the AHJ, to deny this would bring the respective manufacture at odds with this AHJ and possible litigation for breach of freedom of commence.
The difference is that the built car passed inspection post assembly or that the assemblers and assembly line were certified and sample tested. What this kit does is allows us to go to the auto supply store, buy the certified/listed parts so we can assemble a car under a shade tree.Would this be any different from a car manufacture building a car and having it pass all the federal requirements to only have a local authority to deny the sale of that car in there area because it has a 150 mph speedometer?
Up until it's energized, it is just a piece of artwork. That must be there somewhere.Where can I find the section of the NEC that says it only applies to live equipment?
Without electricity use, the code is of non-effect?(A) Practical Safeguarding. The purpose of this Code is the practical safeguarding of persons and property from hazards arising from the use of electricity.
90.2 Scope.
(A) Covered. This Code covers the installation of electrical
conductors, equipment, and raceways; signaling and
communications conductors, equipment, and raceways; and
optical fiber cables and raceways for the following:
(1) Public and private premises, including buildings, structures,
mobile homes, recreational vehicles, and floating
buildings
(2) Yards, lots, parking lots, carnivals, and industrial
substations
(3) Installations of conductors and equipment that connect
to the supply of electricity
(4) Installations used by the electric utility, such as office
buildings, warehouses, garages, machine shops, and
recreational buildings, that are not an integral part of a
generating plant, substation, or control center.
What about switched legs? Do they dissappear from the Premises Wiring (System) when the switch is off?Up until it's energized, it is just a piece of artwork. That must be there somewhere.
The switched leg, when the switch is off, no longer "connects" to the supply of energy.I do see a clear statement that is covers equipment that connects to the supply of electricity, not 'connected' but 'connects'.
I'll buy that. I'll assume Roger would say you can't prove it.I see nothing in there about things being energized or dead.
That's what bugs me. Where is it covered? Is this set-up falling between the cracks? It keeps sounding like to me the proponents are arguing both sides of the fence: it meets code but doesn't have to.I do see a clear statement that is covers equipment that connects to the supply of electricity, not 'connected' but 'connects'.
Nah, they were energized and will be again or are intended to be. I think Roger was saying we could pretend it was not going to be hooked up.What about switched legs? Do they dissappear from the Premises Wiring (System) when the switch is off?
So those installs are not governed by the NEC either?So here we are at post 131 or so and Roger in post #5 said-- How is this different than any stand by generator systems. Most portable generators have a box that has a male end type receptacle that feeds the panel thru a rubber cord from the generator. I don't see this install being much different.
Thanks. I suspect there may be some AHJ that don't know what to do with it. What do you do with an odd-looking beast: ignore it, shoot it, poke it, or pet it? I'm still poking it with a stick. :grin:As a note, no other AHJ has contacted us or made any claim of violation in the past 4 years of the product kit being available.
Regards,
Justin
Until you get home and find out the wife had Handy Hank come by and put one in since you hadn't gotten around to it yet. :grin:I can't lose sleep over it. :grin:
That's the point, it doesn't, so forgetting the cord assembly, you tell me, what is the violation of installing the other components of this system?Where can I find the section of the NEC that says it only applies to live equipment?
