LarryFine
- Henrico County, VA
- Electrical Contractor
That presumes that typical NEC-approved wiring methods are the only way to accomplish this. A flexible extension cord could be used, too. This method avoids the illegal use of cord behind building finishes.If a homeowner didn?t want to use a system like yours, and didn?t want ugly wires to be visible, then what choices remain? Well, have a receptacle outlet installed at the TV?s height, and power it from an existing or new branch circuit. So the power cord that is part of your system does, in fact, act as a substitution for permanent wiring.
NM can be used as in-wall extensions of lighting, even when it's being fed by flexible wire. Look at LV under-cabinet lighting where the transformer is remotely installed. How else could the power be delivered?
Let's say it is an appliance cord. So is the section that is in the wall, which is made of and terminated in NEC-approved materials and methods, respectively. There's no debate the parts are used correctly, right?But yours does not supply an appliance. It supplies something that, in turn, supplies an appliance. Your cord is a middle man, not a final connector. So the reasoning that your cord is no different than an appliance cord does not work for me.
The inlet blades are meant to be energized by a female cord end. The inlet terminals are made to connect to building wire, such as NM. How else can a power inlet be used besides how this method uses it?
The ones I usually use have three screws on the back, similarly to the recessed receptacles, and some have clamped terminals, like this:I can?t speak to this one myself. I have never seen an ?inlet,? and I don?t know how one would be used. I concede that it would have to be powered via a cord. But what is on the other side of the inlet? Is the inlet (i.e., as mentioned in the NEC) intended to describe a component that is physically attached to an item of utilization equipment? Or is the inlet merely an element in the power supply to some remote equipment? Someone would have to help me understand this issue.
Besides, if one cannot supply premises wiring with flexible cord, how are these allowed?:
On the contrary, this product/method is used so a safe, legal, in-wall wiring method can be installed in the wall. Technically speaking, it's no different than using NM as in-wall speaker wiring. Is the voltage the concern?Bob knows perfectly well that you do not intend your system to provide power to other areas of the house, nor to connect it to any other branch circuit. I think his issue is that your system involves a flexible cord that is located outside the wall, and that is used so that the homeowner does not have to install a permanent wire inside the wall.
I've gone as far as passing a power cord through a wall plate with a 1/2" hole in it, knotting it for pull-out proofing, and wire-nutting it to the NM that feeds the recessed receptacle. It isn't part of the premises wiring system.
