I would use two minis on each bell box or other FS style box.
Buy the minis to fit the pipe and nut and bolt the boxes to the minis.
I am sorry but what is a minis?
Only if you need strut. Otherwise, just use 1/2" long 1/4"x20 bolts and nuts to mount the box directly to the straps, and mount the straps to the pipe. See pic:On the inch and half light bar I should mount strut and use these hangers to support the conduit that feeds the outlet boxes.
Thank you very much. How would you support the conduit?
1/16th inch aircraft cable with those adjustable thingy's, that allow you to shorten
or lengthen the cable. What's that name ?
