I appreciate your time.  This person would like to run a ground source heat pump.  I am looking into a deisel generator with some form of battery charging system and convertor.   He wants to be able to keep his cabin warm while he is gone.  I think he should invest in a sytem that can be used for the entire house...
Not certain that this is a good idea.
A heat pump heats the home whilst cooling the air, water or soil outside.
Under good conditions about 3 times as much heat is produced as would result from the same KW input to electric resistance heating.
However a diesel generator might be only 30% efficient.
A liter of diesel fuel burnt in a small diesel generator might produce 3.5 KWH, this would produce up to 10.5 KWH of heat if used to power a heat pump under ideal conditions.
Both the generator and the heat pump are costly articles that require service and repair, and might need to be duplicated to ensure reliable heating.
If instead the liter of diesel fuel was burnt in efficient oil heater it would produce about 10.5 KWH of heat. Much cheaper and simpler, far less to go wrong. Could be duplicated at relatively little cost if desired.
Presuming that natural gas is not available, which it probably is not in a remote area, I would go for an oil burning heater with a small diesel generator for battery charging and powering small appliances.
Alternatively consider a propane heater and a small propane generator.
Propane lights are available, these could be a useful standby in a remote location if something goes wrong with the electrics.
