I guess I did not give all the required info. The satellite terminal is ruggized self sustainable mobile unit. It has 2 12v backup batteries in lieu of an UPS. It has two inverters for the AC to DC conversion in case of loss of AC to convert to the backup batteries. The back-up batteries are charged with an installed battery charger. All the equipment in the racks require 120v to operate. I believe it has two 120v lines as one is dedicated to the High Power Amplifier and the other line is for everything else, i.e. modem, router, media converter, laptop, etc. It has an on-board 7.5K generator that is supposed to be utilized as an Auxillary Power Unit and the systems is supposed to utilize a seperate 10K as it's main power supply. It is cabled into the generator with a pig-tail with the hot wires going to L1 and L3, and the neutral and ground connected to their respective positions. The warehouse has regular outlet connections of 120/208. The question is, what materials would be need to hook the pigtail up to the shore power of the warehouse. I think I better explained it this time. Let me know know if more info is needed!
