Furniture system
Alwayslearningelec
NJ
Estimator
What is the most common applications when you have a furniture system that shows an "in-feed" for the tele/data? Is the jack and plate part of the furniture and you just run the cable through the furniture and terminate? THanks.
Depends on the furniture. I believe all manufacturers have plates that will accept keystone jacks but the big question is whether you can get them, especially if the furniture is old and used and if they will fit your particular brand of keystone jack to begin with.
The times that I had to do a job like that the furniture was always used with little chance of getting other than what it came with. I ran the cables in the wireways and brought it out to surface jack housings for each phone and computer location. The jack housings accept keystone jacks.
-Hal
-Hal
I am referring to brand new furniture. Thanks.
The new furniture I have wired for voice/data was stamped and tapped for for the plate 6/32. I simply pulled through the furniture, knocked the stamp out where I wanted to mount the plate, terminated and screwed plate fast. I should tell you, this was expensive free standing furniture not your typical cubicule partitions.
Thanks.
