Working in a manufacturing plant moving equipment(Melton Welders) and each piece of welding equipment has a ground rod installed and connected via bare cu conductor to a mechanical lug on welder frame. The supply voltage to equipment is 480V 3 ph with ground. I'm wondering if the ground rod is required since there is an EGC run with the supply conductors? Is the current installation considered a parallel path to ground? Does 250.32(B)(1) apply?
