jssegaloff
i am installing multiple roof top exhaust fans on a flat rubber roof.  Units came came pre-assembled with weather proof disconnects on the outside.  to feed these, i understand future maintance requires these to be able to be taken off to be cleaned without having to physically disconnect any conduit.  i currently have holes drilled about 16" away from the curb of the unit.  it is impossible to go into the curb. my question is as follows:   can i stub up the emt thru the flat roof with no supports other then a 3 inch piece of strut cut with a strut clip pressed down against the base of the penetration and tight to the roof (inside the witches hat), with also another strut clip, supported from framing members below roof line; then, change over to liquidtite above the witches hat and not then support until within a foot from the disconnect.  there would be about 2 feet of emt sticking up and then no more then 5 feet of liquidtite????
