How best to split leads from generator
hgar
Hello:
I am brand new to membership in the forum but have been reading it for years.I am installing a 40Kw single phase non-separately derived generator about 100' from a residence. The residence has already installed two 200A transfer switches, two 200 A service entrance breakers and two 200 A Panels. The neutrals are all tied together in the ATS's. I plan on running three 4/0 AL conductors, L1, L2, and neutral from the circuit breaker on the generator and a number 6 bare equipment bonding wire connected to ground rods at the generator and bonded at the generator frame to the ground terminal in one of the ATS's. These 4 wires will enter the house very close, 3' from the ATS's. I am trying to figure out the best way to split these 4/0 cables so I have a set for each ATS. I am assuming a junction box is needed and all wires could enter and exit the box on the same side with no bending required if the right kind of connectors are used. I have not had the occasion to splice or tap these size wires in a box before and I am asking for advice on how best to accomplish this.There is not enough room in the ATS's to install anything that would accomplish this purpose.
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
