JWW
New member
- Hanahan, SC
Why is it recommended to open or close 480 volt breakers etc...with your left hand? Many electricians are concerned that they are exposed to greater danger if the equipment blows and the door opens.
I don't think it matters which hand you use as long as there is no short circuit present then you shoud be fine either way...![]()
Gotta love themI don't use either hand, we use remote operators for all breaker operations nowadays.
That thing is worthless, remote operator for remote operated breakers. Just a one trick pony for pistol grips. Mine can wirelessly close any breaker, switch, or MCC out there.
You're probably in the less than one percent category. The other 99% of us use our hands...
That's not entirely fair IMHO. Yes it is very limited in what it can do but it works for what is intended for. I have 20+ pistol grip operated VCB's in our switchgear building and these things work just fine as long as the cord is long enough to get out of the arc flash zone.
Or a link?
Here you go, EC&M 2011 POY winner. You use the same base system and different attachments for different styles of breakers, MCC's, molded case, switches, etc.. They even have attachments that can charge manually operated breakers, close, and trip them without getting near the breaker. Everything is attached magnetically, no need to modify the equipment. http://www.remoterackingsolutions.com/remote-switch-operators.htm
I was taught to operate from the hinge side of the enclosure.
