straynote6
The "so called instructor" is me and based on your answer, I would give you an F as well.
Strange as it may seem, last night I had a student verbally (and out loud) challenge me about a question I marked wrong on his test.
The question: What is the formula for Apparent Power?
Correct answer = Papp = IV
His answer: IV
I marked it wrong and he became livid. Shouting profanity laced comments.
Was I wrong and too critical?
By the way, his final test score was 99%.
The question asked for a fomula, not an equivalent factor. Technically, the answer was wrong.
That said, the question was inadequate, in that it did not say whether you were asking about a single phase or three phase system. Your answer is right for a single phase system, but your answer was only half right, since there were two possible answers.
The aforementioned student has recently gained my respect immensely. Not only does he show me respect (whether I deserve it or not), but - to be point blank - he is like a new man. Or maybe I've changed, I don't know.
He is one of the most gifted students I have - very bright and very willing to learn. He always asks great questions and now challenges me to step up to the plate and try to become a better teacher.
Hats off to John (not his real name, of course). Should the time ever arise, I'd gladly buy you a jar of suds. Keep pressing on.
My answer would be:
The formula for apparent power, S, is:
S= the square root of ( P squared + Q squared)
measured in VA
P = true power measured in watts
Q = reactive power measured in VAR
This shows you that apparent power is a larger number than true power( unless Q is zero) and how we arrive at apparent power. It also leads to the topic of vectors/triangles.
IMHO, Papp=IV can confuse a student because real power is volts x amps, so what's the difference?
Could you please do some research on the accuracy of my answer and change my grade to "A"?
Incidentally, the "so-called instructor" is me-I constantly learn from students and other instructors in the quest for perfect test questions.
With respect, I think that is totally out of context with the original straightforward question.My answer would be:
measured in VA
It is for DC but the question was about apparent power and that should clue you in that the question is clearly in reference to AC circuits.IMHO, Papp=IV can confuse a student because real power is volts x amps,
Power factor, obviously.so what's the difference?
Not a cat in Hades chance........Could you please do some research on the accuracy of my answer and change my grade to "A"?
