dcw6363
 - Madison, WI
I'm new to the field and there's something I don't understand about wattage in multi-lamp fixtures (specifically tube fluorescent light fixtures). Well actually there's a lot I don't understand about electrictal systems in general, but let's start here.
I keep seeing charts that list specs of various fluorescent tube fixtures, T8 vs. T12 etc.
example: http://www1.eere.energy.gov/femp/pdfs/fluor_lamps.pdf (second page)
The chart will list a multi-lamp fixture and its input power, but the overall input power for the fixture is less than the power required if you added the power for the mutiple lamps. So in the chart on p. two of the link above, a "T8, 32 watts, electronic ballast, two lamp" fixture runs on 57 watts.
I would have thought a fixture w/ two 32-watt lamps would require 64 watts for those lamps (plus ballast power).
I guess the wattage required for input of the whole fixture doesn't just add the wattage of each component?
