Is NM cable an allowable wiring means in a pole barn? This is wood construction with a conventional truss system roof and 6"x6" posts on 10' centers. I don't know what type of consruction this would be considered. Type 111,IV, or V. Do the cables need to be concealed in order to achieve a 15 minute finish rating. My first thought when I looked at it was that it should be done in EMT, but if NM cable is an acceptable means I'm sure the owner will opt for the least expensive route. Building is 60'x120' w/ 14' ceilings. Thanks
