hillbilly1
- North Georgia mountains
- Owner/electrical contractor
The multiple wires are used to either incorporate the integral switch that opens when the breaker is tripped, or to bypass-it. If you bypass it, make sure that the trip signal is momentary so that you don't burn up the coil by keeping power on it.
Hope this link works: http://www.google.com/imgres?q=shunt+trip&hl=en&sa=X&rls=com.microsoft:en-us:IE-SearchBox&tbm=isch&prmd=ivns&tbnid=ZK4o0nfeeThDmM:&imgrefurl=http://www.carlingtech.com/products/circuit-protection/learn_more.asp%253Fpage%253Dcircuit_circuit&docid=vaaxnGdAQfMriM&w=360&h=160&ei=Smk4Tq7aE6r20gGNucCzAw&zoom=1&iact=hc&vpx=723&vpy=262&dur=9547&hovh=128&hovw=288&tx=191&ty=78&page=1&tbnh=72&tbnw=161&start=0&ndsp=35&ved=1t:429,r:11,s:0&biw=1280&bih=853
It's actually been found out to be a latching contactor, these type don't look like a regular contactor, because they are low profile to fit inside a panelboard enclosure. they have built in clearing contacts, so constant voltage is Ok. Something like this: http://www.emersonnetworkpower.com/en-US/Products/PowerSwitchingandControls/IndustrialControls/LightingControls/Pages/ASCO920LightingContactorsforFeederCircuits.aspx
