Spiking of cables
You sure you are not thinking of staking cables. Had an engineer that wanted 15KV direct buried cable staked and tied before being back filled with sand. He wanted them kept in a tight triangle shaped group with no cross overs.
When should cables be "spiked" and how should it be done?
The video Ron referred to is good to see what a spike test is on a cable. When done in the field it is done to verify that a cable has be de-energized prior to cutting the cable. In the utility we speared (spiked) a cable using an hydraulic spear with the manual pump located away from the manhole (just in case we got the wrong one). The spear penetrates the jacket and shorts the conductors.
