In a three gang switch box in a residential home where you may have say 5, 14/2 conductors entering the box, can you twist all the grounds together then either use a buchanon  or a green wirenut then have just one ground wire long enough to attach to three switches instead of having three seperate ground wires? Also how about the black feed wire, can you have a very long feed wire and remove sections of insulation from the wire and wrap around for three switches?
